Title | Size | Downloads |
07-ACL and QoS Configuration Guide-book.pdf | 736.26 KB |
Preface
This configuration guide describes the ACL and QoS fundamentals and configuration procedures. It covers the following items:
· IPv4 ACLs and IPv6 ACLs.
· Packet filtering by using ACLs.
· Traffic control by using QoS polices.
· Common QoS techniques such as traffic policing, congestion management, and congestion avoidance.
· Audience
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Obtaining documentation
To access the most up-to-date H3C product documentation, go to the H3C website at
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
Documentation feedback
We appreciate your comments.
